Time Before: 0.01861 seconds
Time After: 0.02522 seconds
Time Taken: 0.00661 seconds
Time Before: 0.02534 seconds
Time After: 0.02574 seconds
Time Before: 0.02595 seconds
Time After: 0.02610 seconds
Time Before: 0.02679 seconds
Time After: 0.02870 seconds
Time Taken: 0.00191 seconds
Time Before: 0.02616 seconds
Time After: 0.03282 seconds
Time Taken: 0.00666 seconds
Time Before: 0.03863 seconds
Time After: 0.03902 seconds
Time Before: 0.04043 seconds
Time After: 0.04164 seconds
Time Before: 0.03797 seconds
Time After: 0.04182 seconds
Time Taken: 0.00385 seconds
Time Before: 0.06661 seconds
Time After: 0.06698 seconds
Time Before: 0.08416 seconds
Time After: 0.08544 seconds
Time Before: 0.09834 seconds
Time After: 0.09849 seconds
Time Before: 0.10114 seconds
Time After: 0.10258 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=146709' WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.12109 seconds
Time After: 0.12136 seconds
Memory Before: 4,287.922 KB
Memory After: 4,288.164 KB
