Time Before: 0.01692 seconds
Time After: 0.02639 seconds
Time Taken: 0.00946 seconds
Time Before: 0.02648 seconds
Time After: 0.02694 seconds
Time Before: 0.02714 seconds
Time After: 0.02725 seconds
Time Before: 0.02793 seconds
Time After: 0.02983 seconds
Time Taken: 0.00190 seconds
Time Before: 0.02730 seconds
Time After: 0.03441 seconds
Time Taken: 0.00711 seconds
Time Before: 0.04297 seconds
Time After: 0.04327 seconds
Time Before: 0.04765 seconds
Time After: 0.04890 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.04233 seconds
Time After: 0.04913 seconds
Time Taken: 0.00680 seconds
Memory After: 2,261.703 KB
Time Before: 0.07317 seconds
Time After: 0.07332 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.09162 seconds
Time After: 0.09285 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
End call of global.php: 0.094948053359985
Time Before: 0.10195 seconds
Time After: 0.10218 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.10447 seconds
Time After: 0.10596 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=146826', badlocation = 1
Time Before: 0.12517 seconds
Time After: 0.12547 seconds
Memory Before: 4,287.469 KB
Memory After: 4,287.695 KB
Page generated in 0.12401008605957 seconds with 9 queries, spending 0.0074026584625244 doing MySQL queries and 0.11660742759705 doing PHP things.
