Time Before: 0.00338 seconds
Time After: 0.00508 seconds
Time Taken: 0.00170 seconds
Time Before: 0.00518 seconds
Time After: 0.00568 seconds
Time Before: 0.00593 seconds
Time After: 0.00605 seconds
Time Before: 0.00684 seconds
Time After: 0.00975 seconds
Time Taken: 0.00291 seconds
Time Before: 0.00610 seconds
Time After: 0.01320 seconds
Time Taken: 0.00711 seconds
Time Before: 0.01628 seconds
Time After: 0.01684 seconds
Time Taken: 0.00057 seconds
Time Before: 0.01943 seconds
Time After: 0.02077 seconds
Time Taken: 0.00134 seconds
Time Before: 0.01565 seconds
Time After: 0.02094 seconds
Time Taken: 0.00529 seconds
Time Before: 0.02624 seconds
Time After: 0.02638 seconds
Time Before: 0.02878 seconds
Time After: 0.03007 seconds
End call of global.php: 0.032590866088867
Time Before: 0.03545 seconds
Time After: 0.03565 seconds
Time Before: 0.03841 seconds
Time After: 0.04011 seconds
SET lastactivity = 1789123784, location = '/forums/private.php?do=newpm&explain=1&u=146870', badlocation = 1
Time Before: 0.05559 seconds
Time After: 0.05601 seconds
Page generated in 0.054647922515869 seconds with 9 queries, spending 0.0091831684112549 doing MySQL queries and 0.045464754104614 doing PHP things.
