Time Before: 0.01974 seconds
Time After: 0.02684 seconds
Time Taken: 0.00710 seconds
Time Before: 0.02693 seconds
Time After: 0.02735 seconds
Time Before: 0.02756 seconds
Time After: 0.02768 seconds
Time Before: 0.02846 seconds
Time After: 0.03084 seconds
Time Taken: 0.00238 seconds
Time Before: 0.02773 seconds
Time After: 0.03627 seconds
Time Taken: 0.00854 seconds
Time Before: 0.04722 seconds
Time After: 0.04764 seconds
Time Before: 0.05088 seconds
Time After: 0.05211 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.04624 seconds
Time After: 0.05235 seconds
Time Taken: 0.00611 seconds
Memory After: 2,261.820 KB
Time Before: 0.08013 seconds
Time After: 0.08027 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.09665 seconds
Time After: 0.09789 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
End call of global.php: 0.099977016448975
Time Before: 0.10834 seconds
Time After: 0.10849 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.11086 seconds
Time After: 0.11231 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
SET lastactivity = 1789019318, location = '/forums/private.php?do=newpm&explain=1&u=146904'
Time Before: 0.13071 seconds
Time After: 0.13126 seconds
Time Taken: 0.00055 seconds
Memory Before: 4,287.563 KB
Memory After: 4,287.781 KB
Page generated in 0.12973713874817 seconds with 9 queries, spending 0.0081076622009277 doing MySQL queries and 0.12162947654724 doing PHP things.
