Time Before: 0.01736 seconds
Time After: 0.02427 seconds
Time Taken: 0.00691 seconds
Time Before: 0.02439 seconds
Time After: 0.02501 seconds
Time Taken: 0.00062 seconds
Time Before: 0.02537 seconds
Time After: 0.02552 seconds
Time Before: 0.02629 seconds
Time After: 0.02827 seconds
Time Taken: 0.00198 seconds
Time Before: 0.02561 seconds
Time After: 0.03363 seconds
Time Taken: 0.00802 seconds
Time Before: 0.03898 seconds
Time After: 0.03934 seconds
Time Before: 0.04179 seconds
Time After: 0.04300 seconds
Time Before: 0.03833 seconds
Time After: 0.04318 seconds
Time Taken: 0.00485 seconds
Time Before: 0.07529 seconds
Time After: 0.07558 seconds
Time Before: 0.09014 seconds
Time After: 0.09145 seconds
Time Taken: 0.00131 seconds
End call of global.php: 0.093590021133423
Time Before: 0.10115 seconds
Time After: 0.10135 seconds
Time Before: 0.10367 seconds
Time After: 0.10523 seconds
Time Taken: 0.00155 seconds
SET lastactivity = 1789111351, location = '/forums/private.php?do=newpm&explain=1&u=146907'
Time Before: 0.12228 seconds
Time After: 0.12257 seconds
Page generated in 0.12129187583923 seconds with 9 queries, spending 0.0079448223114014 doing MySQL queries and 0.11334705352783 doing PHP things.
