Time Before: 0.00142 seconds
Time After: 0.00199 seconds
Time Taken: 0.00057 seconds
Time Before: 0.00209 seconds
Time After: 0.00266 seconds
Time Before: 0.00286 seconds
Time After: 0.00299 seconds
Time Before: 0.00364 seconds
Time After: 0.00661 seconds
Time Taken: 0.00297 seconds
Time Before: 0.00304 seconds
Time After: 0.01148 seconds
Time Taken: 0.00844 seconds
Time Before: 0.01375 seconds
Time After: 0.01432 seconds
Time Before: 0.01686 seconds
Time After: 0.01855 seconds
Time Taken: 0.00169 seconds
Time Before: 0.01310 seconds
Time After: 0.01875 seconds
Time Taken: 0.00566 seconds
Time Before: 0.02510 seconds
Time After: 0.02532 seconds
Time Before: 0.02722 seconds
Time After: 0.02847 seconds
Time Before: 0.03181 seconds
Time After: 0.03196 seconds
Time Before: 0.03398 seconds
Time After: 0.03541 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=146912', badlocation = 1 WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.04778 seconds
Time After: 0.04809 seconds
