Time Before: 0.00234 seconds
Time After: 0.00361 seconds
Time Before: 0.00369 seconds
Time After: 0.00433 seconds
Time Taken: 0.00065 seconds
Time Before: 0.00460 seconds
Time After: 0.00474 seconds
Time Before: 0.00548 seconds
Time After: 0.00755 seconds
Time Taken: 0.00207 seconds
Time Before: 0.00481 seconds
Time After: 0.01100 seconds
Time Taken: 0.00619 seconds
Time Before: 0.01317 seconds
Time After: 0.01369 seconds
Time Before: 0.01529 seconds
Time After: 0.01646 seconds
Time Taken: 0.00117 seconds
Time Before: 0.01252 seconds
Time After: 0.01665 seconds
Time Taken: 0.00413 seconds
Memory After: 2,885.109 KB
Memory Used: 132.781 KB
Time Before: 0.02206 seconds
Time After: 0.02221 seconds
Memory Before: 3,438.211 KB
Memory After: 3,438.727 KB
Time Before: 0.02425 seconds
Time After: 0.02549 seconds
Memory Before: 3,525.906 KB
Memory After: 3,526.500 KB
End call of global.php: 0.027796030044556
Time Before: 0.02947 seconds
Time After: 0.02963 seconds
Memory Before: 4,163.813 KB
Memory After: 4,164.242 KB
Time Before: 0.03293 seconds
Time After: 0.03438 seconds
Memory Before: 4,445.375 KB
Memory After: 4,447.063 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=147002'
Time Before: 0.05312 seconds
Time After: 0.05341 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
Page generated in 0.052050113677979 seconds with 9 queries, spending 0.0078403949737549 doing MySQL queries and 0.044209718704224 doing PHP things.
