Time Before: 0.01323 seconds
Time After: 0.01695 seconds
Time Taken: 0.00373 seconds
Time Before: 0.01703 seconds
Time After: 0.01750 seconds
Time Before: 0.01933 seconds
Time After: 0.01949 seconds
Time Before: 0.02039 seconds
Time After: 0.02277 seconds
Time Taken: 0.00238 seconds
Time Before: 0.01958 seconds
Time After: 0.02623 seconds
Time Taken: 0.00666 seconds
Time Before: 0.03116 seconds
Time After: 0.03153 seconds
Time Before: 0.03290 seconds
Time After: 0.03407 seconds
Time Taken: 0.00117 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.03060 seconds
Time After: 0.03432 seconds
Memory After: 2,261.703 KB
Time Before: 0.05941 seconds
Time After: 0.05956 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.07134 seconds
Time After: 0.07353 seconds
Time Taken: 0.00218 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 0.08313 seconds
Time After: 0.08336 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.08578 seconds
Time After: 0.08719 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=147060', badlocation = 1 WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.10368 seconds
Time After: 0.10412 seconds
Memory Before: 4,287.469 KB
Memory After: 4,287.695 KB
