Time Before: 0.00146 seconds
Time After: 0.00194 seconds
Time Before: 0.00201 seconds
Time After: 0.00261 seconds
Time Taken: 0.00061 seconds
Time Before: 0.00289 seconds
Time After: 0.00304 seconds
Time Before: 0.00378 seconds
Time After: 0.00708 seconds
Time Taken: 0.00330 seconds
Time Before: 0.00309 seconds
Time After: 0.01046 seconds
Time Taken: 0.00737 seconds
Time Before: 0.01263 seconds
Time After: 0.01306 seconds
Time Before: 0.01627 seconds
Time After: 0.01774 seconds
Time Before: 0.01199 seconds
Time After: 0.01793 seconds
Time Taken: 0.00594 seconds
Time Before: 0.02471 seconds
Time After: 0.02486 seconds
Time Before: 0.02754 seconds
Time After: 0.02879 seconds
End call of global.php: 0.031309127807617
Time Before: 0.03270 seconds
Time After: 0.03291 seconds
Time Before: 0.03560 seconds
Time After: 0.03701 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=147086', badlocation = 1
Time Before: 0.05062 seconds
Time After: 0.05090 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
Page generated in 0.049706935882568 seconds with 9 queries, spending 0.009246826171875 doing MySQL queries and 0.040460109710693 doing PHP things.
