Time Before: 0.01640 seconds
Time After: 0.01968 seconds
Time Taken: 0.00328 seconds
Time Before: 0.01979 seconds
Time After: 0.02026 seconds
Time Before: 0.02053 seconds
Time After: 0.02069 seconds
Time Before: 0.02144 seconds
Time After: 0.02411 seconds
Time Taken: 0.00267 seconds
Time Before: 0.02075 seconds
Time After: 0.02843 seconds
Time Taken: 0.00768 seconds
Time Before: 0.03422 seconds
Time After: 0.03446 seconds
Time Before: 0.03729 seconds
Time After: 0.03960 seconds
Time Taken: 0.00231 seconds
Time Before: 0.03350 seconds
Time After: 0.03984 seconds
Time Taken: 0.00634 seconds
Time Before: 0.06067 seconds
Time After: 0.06085 seconds
Time Before: 0.07674 seconds
Time After: 0.07799 seconds
End call of global.php: 0.080401182174683
Time Before: 0.08697 seconds
Time After: 0.08712 seconds
Time Before: 0.08958 seconds
Time After: 0.09123 seconds
Time Taken: 0.00165 seconds
SET lastactivity = 1783020700, location = '/forums/private.php?do=newpm&explain=1&u=147094', badlocation = 1
Time Before: 0.10916 seconds
Time After: 0.10952 seconds
Memory Before: 4,912.320 KB
Memory After: 4,912.531 KB
Page generated in 0.10802102088928 seconds with 9 queries, spending 0.0094428062438965 doing MySQL queries and 0.098578214645386 doing PHP things.
