Time Before: 0.00176 seconds
Time After: 0.00228 seconds
Time Before: 0.00235 seconds
Time After: 0.00281 seconds
Time Before: 0.00301 seconds
Time After: 0.00314 seconds
Time Before: 0.00390 seconds
Time After: 0.00755 seconds
Time Taken: 0.00365 seconds
Time Before: 0.00319 seconds
Time After: 0.01200 seconds
Time Taken: 0.00881 seconds
Time Before: 0.01405 seconds
Time After: 0.01451 seconds
Time Before: 0.01687 seconds
Time After: 0.01802 seconds
Time Taken: 0.00115 seconds
Time Before: 0.01349 seconds
Time After: 0.01820 seconds
Time Taken: 0.00472 seconds
Time Before: 0.02328 seconds
Time After: 0.02343 seconds
Time Before: 0.02604 seconds
Time After: 0.02747 seconds
Time Before: 0.03141 seconds
Time After: 0.03165 seconds
Time Before: 0.03385 seconds
Time After: 0.03528 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=147157' WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.04997 seconds
Time After: 0.05023 seconds
