Time Before: 0.02024 seconds
Time After: 0.02831 seconds
Time Taken: 0.00807 seconds
Memory Before: 533.930 KB
Memory After: 559.047 KB
Time Before: 0.02843 seconds
Time After: 0.02892 seconds
Memory Before: 558.984 KB
Memory After: 559.992 KB
Time Before: 0.02914 seconds
Time After: 0.02926 seconds
Memory Before: 560.547 KB
Memory After: 561.070 KB
Time Before: 0.03012 seconds
Time After: 0.03214 seconds
Time Taken: 0.00202 seconds
Memory Before: 563.672 KB
Memory After: 564.594 KB
Time Before: 0.02934 seconds
Time After: 0.03627 seconds
Time Taken: 0.00693 seconds
Memory Before: 560.320 KB
Memory After: 1,641.344 KB
Memory Used: 1,081.023 KB
Time Before: 0.04560 seconds
Time After: 0.04607 seconds
Memory Before: 2,136.219 KB
Memory After: 2,136.836 KB
Time Before: 0.04868 seconds
Time After: 0.04987 seconds
Memory Before: 2,148.281 KB
Memory After: 2,148.141 KB
Time Before: 0.04493 seconds
Time After: 0.05010 seconds
Time Taken: 0.00517 seconds
Memory Before: 2,128.398 KB
Memory After: 2,261.164 KB
Time Before: 0.09099 seconds
Time After: 0.09115 seconds
Memory Before: 2,814.719 KB
Memory After: 2,815.234 KB
Time Before: 0.11039 seconds
Time After: 0.11167 seconds
Memory Before: 2,903.047 KB
Memory After: 2,903.641 KB
End call of global.php: 0.11387896537781
Time Before: 0.12458 seconds
Time After: 0.12477 seconds
Memory Before: 3,539.773 KB
Memory After: 3,540.203 KB
Time Before: 0.12770 seconds
Time After: 0.12917 seconds
Memory Before: 3,821.516 KB
Memory After: 3,823.203 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=147250'
Time Before: 0.14927 seconds
Time After: 0.14952 seconds
Memory Before: 4,294.930 KB
Memory After: 4,295.172 KB
Page generated in 0.14830899238586 seconds with 9 queries, spending 0.0076372623443604 doing MySQL queries and 0.1406717300415 doing PHP things.
