Time Before: 0.00361 seconds
Time After: 0.00425 seconds
Time Taken: 0.00064 seconds
Time Before: 0.00435 seconds
Time After: 0.00486 seconds
Time Before: 0.00514 seconds
Time After: 0.00527 seconds
Time Before: 0.00616 seconds
Time After: 0.01256 seconds
Time Taken: 0.00640 seconds
Time Before: 0.00534 seconds
Time After: 0.01714 seconds
Time Taken: 0.01180 seconds
Time Before: 0.01890 seconds
Time After: 0.01927 seconds
Time Before: 0.02215 seconds
Time After: 0.02350 seconds
Time Taken: 0.00135 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.01832 seconds
Time After: 0.02376 seconds
Time Taken: 0.00543 seconds
Memory After: 2,261.719 KB
Time Before: 0.03225 seconds
Time After: 0.03245 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.03507 seconds
Time After: 0.03661 seconds
Time Taken: 0.00154 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
Time Before: 0.04080 seconds
Time After: 0.04099 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.04412 seconds
Time After: 0.04566 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=14732' WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.06531 seconds
Time After: 0.06558 seconds
Memory Before: 4,287.219 KB
Memory After: 4,287.461 KB
