Time Before: 0.00356 seconds
Time After: 0.00489 seconds
Time Taken: 0.00133 seconds
Time Before: 0.00499 seconds
Time After: 0.00543 seconds
Time Before: 0.00567 seconds
Time After: 0.00583 seconds
Time Before: 0.00661 seconds
Time After: 0.00900 seconds
Time Taken: 0.00238 seconds
Time Before: 0.00589 seconds
Time After: 0.01245 seconds
Time Taken: 0.00656 seconds
Time Before: 0.01542 seconds
Time After: 0.01585 seconds
Time Before: 0.01830 seconds
Time After: 0.01959 seconds
Time Before: 0.01486 seconds
Time After: 0.01977 seconds
Time Taken: 0.00491 seconds
Time Before: 0.02951 seconds
Time After: 0.02975 seconds
REPLACE INTO datastore
(title, data, unserialize)
VALUES
('loadcache', 'a:2:{s:7:\"loadavg\";s:5:\"8.27,\";s:9:\"lastcheck\";i:1785412687;}', 1)Time Before: 0.03575 seconds
Time After: 0.03625 seconds
Memory Before: 2,817.297 KB
Memory After: 2,817.547 KB
Memory Used: 0.250 KB
Time Before: 0.03986 seconds
Time After: 0.04118 seconds
Time Taken: 0.00132 seconds
Memory Before: 2,904.625 KB
Memory After: 2,905.219 KB
Time Before: 0.04562 seconds
Time After: 0.04577 seconds
Memory Before: 3,541.398 KB
Memory After: 3,541.828 KB
Time Before: 0.04809 seconds
Time After: 0.04953 seconds
Memory Before: 3,823.141 KB
Memory After: 3,824.828 KB
UPDATE session SET lastactivity = 1785412687, location = '/forums/private.php?do=newpm&explain=1&u=147388' WHERE sessionhash = 'dd14cf6af34df6bab38ac9fb3783395f'
Time Before: 0.06250 seconds
Time After: 0.06279 seconds
Memory Before: 4,296.844 KB
Memory After: 4,297.070 KB
