Time Before: 0.01049 seconds
Time After: 0.01434 seconds
Time Taken: 0.00385 seconds
Time Before: 0.01444 seconds
Time After: 0.01482 seconds
Time Before: 0.01501 seconds
Time After: 0.01523 seconds
Time Before: 0.01626 seconds
Time After: 0.01981 seconds
Time Taken: 0.00354 seconds
Time Before: 0.01530 seconds
Time After: 0.02534 seconds
Time Taken: 0.01003 seconds
Time Before: 0.03228 seconds
Time After: 0.03271 seconds
Time Before: 0.03547 seconds
Time After: 0.03700 seconds
Time Taken: 0.00154 seconds
Time Before: 0.03153 seconds
Time After: 0.03725 seconds
Time Taken: 0.00571 seconds
Time Before: 0.06431 seconds
Time After: 0.06447 seconds
Time Before: 0.07735 seconds
Time After: 0.07861 seconds
End call of global.php: 0.080969095230103
Time Before: 0.08578 seconds
Time After: 0.08594 seconds
Time Before: 0.08898 seconds
Time After: 0.09052 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=147413', badlocation = 1
Time Before: 0.10744 seconds
Time After: 0.10772 seconds
Page generated in 0.10624694824219 seconds with 9 queries, spending 0.0094962120056152 doing MySQL queries and 0.096750736236572 doing PHP things.
