Time Before: 0.02542 seconds
Time After: 0.03220 seconds
Time Taken: 0.00678 seconds
Time Before: 0.03231 seconds
Time After: 0.03275 seconds
Time Before: 0.03303 seconds
Time After: 0.03320 seconds
Time Before: 0.03408 seconds
Time After: 0.03658 seconds
Time Taken: 0.00250 seconds
Time Before: 0.03327 seconds
Time After: 0.04080 seconds
Time Taken: 0.00752 seconds
Time Before: 0.05135 seconds
Time After: 0.05172 seconds
Time Before: 0.05434 seconds
Time After: 0.05553 seconds
Time Before: 0.05051 seconds
Time After: 0.05574 seconds
Time Taken: 0.00523 seconds
Time Before: 0.10535 seconds
Time After: 0.10563 seconds
Time Before: 2.14851 seconds
Time After: 2.15010 seconds
Time Taken: 0.00159 seconds
End call of global.php: 2.1531500816345
Time Before: 2.16271 seconds
Time After: 2.16288 seconds
Time Before: 2.16562 seconds
Time After: 2.16711 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=147449', badlocation = 1
Time Before: 2.18703 seconds
Time After: 2.18739 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
Page generated in 2.1855380535126 seconds with 9 queries, spending 0.0085639953613281 doing MySQL queries and 2.1769740581512 doing PHP things.
