Time Before: 0.02431 seconds
Time After: 0.03330 seconds
Time Taken: 0.00898 seconds
Time Before: 0.03340 seconds
Time After: 0.03382 seconds
Time Before: 0.03406 seconds
Time After: 0.03422 seconds
Time Before: 0.03497 seconds
Time After: 0.03726 seconds
Time Taken: 0.00228 seconds
Time Before: 0.03427 seconds
Time After: 0.04157 seconds
Time Taken: 0.00730 seconds
Time Before: 0.04899 seconds
Time After: 0.04938 seconds
Time Before: 0.05186 seconds
Time After: 0.05305 seconds
Time Before: 0.04832 seconds
Time After: 0.05329 seconds
Time Taken: 0.00498 seconds
Time Before: 0.09412 seconds
Time After: 0.09427 seconds
Time Before: 0.11684 seconds
Time After: 0.11812 seconds
Time Before: 0.13329 seconds
Time After: 0.13345 seconds
Time Before: 0.13630 seconds
Time After: 0.13810 seconds
Time Taken: 0.00180 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=147490' WHERE sessionhash = '7ca6ab718f0d2129a0db1a6bd7e3c55b'
Time Before: 0.15811 seconds
Time After: 0.15838 seconds
Memory Before: 4,287.922 KB
Memory After: 4,288.164 KB
