Time Before: 0.00417 seconds
Time After: 0.00483 seconds
Time Taken: 0.00066 seconds
Time Before: 0.00490 seconds
Time After: 0.00547 seconds
Time Taken: 0.00057 seconds
Time Before: 0.00578 seconds
Time After: 0.00596 seconds
Time Before: 0.00660 seconds
Time After: 0.00909 seconds
Time Taken: 0.00249 seconds
Time Before: 0.00601 seconds
Time After: 0.01493 seconds
Time Taken: 0.00891 seconds
Time Before: 0.01695 seconds
Time After: 0.01727 seconds
Time Before: 0.01983 seconds
Time After: 0.02109 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.01639 seconds
Time After: 0.02135 seconds
Time Taken: 0.00496 seconds
Memory After: 2,261.820 KB
Time Before: 0.02821 seconds
Time After: 0.02842 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.03066 seconds
Time After: 0.03193 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
End call of global.php: 0.034247875213623
Time Before: 0.03596 seconds
Time After: 0.03617 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.03935 seconds
Time After: 0.04087 seconds
Time Taken: 0.00151 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
SET lastactivity = 1789113759, location = '/forums/private.php?do=newpm&explain=1&u=147498'
Time Before: 0.05457 seconds
Time After: 0.05505 seconds
Memory Before: 4,287.563 KB
Memory After: 4,287.781 KB
Page generated in 0.053621053695679 seconds with 9 queries, spending 0.0085060596466064 doing MySQL queries and 0.045114994049072 doing PHP things.
