Time Before: 0.00224 seconds
Time After: 0.00289 seconds
Time Taken: 0.00065 seconds
Time Before: 0.00300 seconds
Time After: 0.00355 seconds
Time Taken: 0.00055 seconds
Time Before: 0.00383 seconds
Time After: 0.00399 seconds
Time Before: 0.00491 seconds
Time After: 0.00710 seconds
Time Taken: 0.00219 seconds
Time Before: 0.00411 seconds
Time After: 0.01193 seconds
Time Taken: 0.00782 seconds
Time Before: 0.01386 seconds
Time After: 0.01430 seconds
Time Before: 0.01701 seconds
Time After: 0.01835 seconds
Time Taken: 0.00134 seconds
Time Before: 0.01331 seconds
Time After: 0.01860 seconds
Time Taken: 0.00529 seconds
Time Before: 0.02474 seconds
Time After: 0.02489 seconds
Time Before: 0.02689 seconds
Time After: 0.02811 seconds
Time Before: 0.03143 seconds
Time After: 0.03158 seconds
Time Before: 0.03390 seconds
Time After: 0.03538 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=1475', badlocation = 1 WHERE sessionhash = 'b910b85238c3231bdc641e11d90490dd'
Time Before: 0.05017 seconds
Time After: 0.05045 seconds
Memory Before: 4,911.086 KB
Memory After: 4,911.313 KB
