Time Before: 0.00153 seconds
Time After: 0.00210 seconds
Time Taken: 0.00057 seconds
Time Before: 0.00217 seconds
Time After: 0.00277 seconds
Time Taken: 0.00060 seconds
Time Before: 0.00302 seconds
Time After: 0.00318 seconds
Time Before: 0.00383 seconds
Time After: 0.00694 seconds
Time Taken: 0.00310 seconds
Time Before: 0.00323 seconds
Time After: 0.01031 seconds
Time Taken: 0.00708 seconds
Time Before: 0.01232 seconds
Time After: 0.01278 seconds
Time Before: 0.01512 seconds
Time After: 0.01643 seconds
Time Taken: 0.00131 seconds
Time Before: 0.01170 seconds
Time After: 0.01660 seconds
Time Taken: 0.00490 seconds
Time Before: 0.02165 seconds
Time After: 0.02183 seconds
Time Before: 0.02385 seconds
Time After: 0.02516 seconds
End call of global.php: 0.02673602104187
Time Before: 0.02793 seconds
Time After: 0.02813 seconds
Time Before: 0.03015 seconds
Time After: 0.03163 seconds
SET lastactivity = 1784763175, location = '/forums/private.php?do=newpm&explain=1&u=147507', badlocation = 1
Time Before: 0.04383 seconds
Time After: 0.04420 seconds
Page generated in 0.042946100234985 seconds with 9 queries, spending 0.0091531276702881 doing MySQL queries and 0.033792972564697 doing PHP things.
