Time Before: 0.01218 seconds
Time After: 0.01708 seconds
Time Taken: 0.00490 seconds
Time Before: 0.01718 seconds
Time After: 0.01792 seconds
Time Taken: 0.00074 seconds
Time Before: 0.01831 seconds
Time After: 0.01869 seconds
Time Before: 0.01958 seconds
Time After: 0.02221 seconds
Time Taken: 0.00262 seconds
Time Before: 0.01876 seconds
Time After: 0.02612 seconds
Time Taken: 0.00736 seconds
Time Before: 0.03265 seconds
Time After: 0.03286 seconds
Time Before: 0.03540 seconds
Time After: 0.03656 seconds
Time Taken: 0.00116 seconds
Time Before: 0.03197 seconds
Time After: 0.03679 seconds
Time Taken: 0.00482 seconds
Time Before: 0.06221 seconds
Time After: 0.06237 seconds
Time Before: 0.38063 seconds
Time After: 0.38207 seconds
Time Before: 0.38922 seconds
Time After: 0.38937 seconds
Time Before: 0.39254 seconds
Time After: 0.39411 seconds
Time Taken: 0.00157 seconds
UPDATE session SET lastactivity = 1783369684, location = '/forums/private.php?do=newpm&explain=1&u=147556', badlocation = 1 WHERE sessionhash = '32502f71822f8bf82bf8c86767d671b1'
Time Before: 0.41070 seconds
Time After: 0.41095 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
