Time Before: 0.02925 seconds
Time After: 0.03929 seconds
Time Taken: 0.01005 seconds
Time Before: 0.03941 seconds
Time After: 0.03996 seconds
Time Taken: 0.00055 seconds
Time Before: 0.04027 seconds
Time After: 0.04043 seconds
Time Before: 0.04125 seconds
Time After: 0.04358 seconds
Time Taken: 0.00233 seconds
Time Before: 0.04050 seconds
Time After: 0.04795 seconds
Time Taken: 0.00745 seconds
Time Before: 0.06231 seconds
Time After: 0.06268 seconds
Time Before: 0.06418 seconds
Time After: 0.06537 seconds
Time Before: 0.06155 seconds
Time After: 0.06563 seconds
Time Taken: 0.00409 seconds
Time Before: 0.10490 seconds
Time After: 0.10506 seconds
Time Before: 0.13343 seconds
Time After: 0.13480 seconds
Time Taken: 0.00137 seconds
Time Before: 0.14988 seconds
Time After: 0.15027 seconds
Time Before: 0.15360 seconds
Time After: 0.15540 seconds
Time Taken: 0.00180 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=14891' WHERE sessionhash = 'b910b85238c3231bdc641e11d90490dd'
Time Before: 0.18126 seconds
Time After: 0.18158 seconds
Memory Before: 4,288.555 KB
Memory After: 4,288.797 KB
