Time Before: 0.01963 seconds
Time After: 0.02386 seconds
Time Taken: 0.00423 seconds
Time Before: 0.02395 seconds
Time After: 0.02444 seconds
Time Before: 0.02470 seconds
Time After: 0.02485 seconds
Time Before: 0.02601 seconds
Time After: 0.02956 seconds
Time Taken: 0.00355 seconds
Time Before: 0.02492 seconds
Time After: 0.03543 seconds
Time Taken: 0.01051 seconds
Time Before: 0.04443 seconds
Time After: 0.04485 seconds
Time Before: 0.04748 seconds
Time After: 0.04874 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.04363 seconds
Time After: 0.04902 seconds
Time Taken: 0.00539 seconds
Memory After: 2,261.719 KB
Time Before: 0.07384 seconds
Time After: 0.07402 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.08891 seconds
Time After: 0.09018 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
Time Before: 0.10140 seconds
Time After: 0.10158 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.10476 seconds
Time After: 0.10623 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=1495', badlocation = 1 WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.12871 seconds
Time After: 0.12913 seconds
Memory Before: 4,287.508 KB
Memory After: 4,287.734 KB
