Time Before: 0.00129 seconds
Time After: 0.00176 seconds
Time Before: 0.00184 seconds
Time After: 0.00231 seconds
Time Before: 0.00259 seconds
Time After: 0.00273 seconds
Time Before: 0.00364 seconds
Time After: 0.00685 seconds
Time Taken: 0.00320 seconds
Time Before: 0.00282 seconds
Time After: 0.01144 seconds
Time Taken: 0.00862 seconds
Time Before: 0.01338 seconds
Time After: 0.01377 seconds
Time Before: 0.01539 seconds
Time After: 0.01677 seconds
Time Taken: 0.00137 seconds
Time Before: 0.01265 seconds
Time After: 0.01701 seconds
Time Taken: 0.00436 seconds
Time Before: 0.02245 seconds
Time After: 0.02259 seconds
Time Before: 0.02443 seconds
Time After: 0.02567 seconds
Time Before: 0.02855 seconds
Time After: 0.02871 seconds
Time Before: 0.03069 seconds
Time After: 0.03214 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=15018', badlocation = 1 WHERE sessionhash = '7f12e449499bf5aa31d8d04cb08a0450'
Time Before: 0.04652 seconds
Time After: 0.04684 seconds
Memory Before: 4,911.938 KB
Memory After: 4,912.164 KB
