Time Before: 0.00214 seconds
Time After: 0.00290 seconds
Time Taken: 0.00076 seconds
Time Before: 0.00300 seconds
Time After: 0.00337 seconds
Time Before: 0.00419 seconds
Time After: 0.00431 seconds
Time Before: 0.00503 seconds
Time After: 0.00746 seconds
Time Taken: 0.00242 seconds
Time Before: 0.00437 seconds
Time After: 0.01091 seconds
Time Taken: 0.00654 seconds
Time Before: 0.01338 seconds
Time After: 0.01379 seconds
Time Before: 0.01727 seconds
Time After: 0.01853 seconds
Time Before: 0.01256 seconds
Time After: 0.01879 seconds
Time Taken: 0.00623 seconds
Time Before: 0.02530 seconds
Time After: 0.02544 seconds
Time Before: 0.02758 seconds
Time After: 0.02887 seconds
End call of global.php: 0.030581951141357
Time Before: 0.03208 seconds
Time After: 0.03223 seconds
Time Before: 0.03448 seconds
Time After: 0.03629 seconds
Time Taken: 0.00181 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=15068'
Time Before: 0.04989 seconds
Time After: 0.09155 seconds
Time Taken: 0.04167 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
Page generated in 0.048956871032715 seconds with 9 queries, spending 0.049639701843262 doing MySQL queries and -0.00068283081054688 doing PHP things.
