Time Before: 0.01514 seconds
Time After: 0.02626 seconds
Time Taken: 0.01112 seconds
Time Before: 0.02635 seconds
Time After: 0.02687 seconds
Time Before: 0.02716 seconds
Time After: 0.02733 seconds
Time Before: 0.02813 seconds
Time After: 0.03052 seconds
Time Taken: 0.00238 seconds
Time Before: 0.02740 seconds
Time After: 0.03593 seconds
Time Taken: 0.00853 seconds
Time Before: 0.04833 seconds
Time After: 0.04873 seconds
Time Before: 0.05139 seconds
Time After: 0.05267 seconds
Time Before: 0.04676 seconds
Time After: 0.05287 seconds
Time Taken: 0.00611 seconds
Time Before: 0.07262 seconds
Time After: 0.07279 seconds
Time Before: 0.09229 seconds
Time After: 0.09375 seconds
Time Before: 0.10685 seconds
Time After: 0.10703 seconds
Time Before: 0.10977 seconds
Time After: 0.11248 seconds
Time Taken: 0.00271 seconds
UPDATE session SET lastactivity = 1789093093, location = '/forums/private.php?do=newpm&explain=1&u=15090', badlocation = 1 WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.13145 seconds
Time After: 0.13193 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
