Time Before: 0.02617 seconds
Time After: 0.03616 seconds
Time Taken: 0.00999 seconds
Memory Before: 1,157.773 KB
Memory After: 1,182.891 KB
Time Before: 0.03627 seconds
Time After: 0.03667 seconds
Memory Before: 1,182.828 KB
Memory After: 1,183.836 KB
Time Before: 0.03689 seconds
Time After: 0.03705 seconds
Memory Before: 1,184.422 KB
Memory After: 1,184.945 KB
Time Before: 0.03786 seconds
Time After: 0.04064 seconds
Time Taken: 0.00278 seconds
Memory Before: 1,187.547 KB
Memory After: 1,188.469 KB
Time Before: 0.03713 seconds
Time After: 0.04495 seconds
Time Taken: 0.00783 seconds
Memory Before: 1,184.164 KB
Memory After: 2,265.219 KB
Memory Used: 1,081.055 KB
Time Before: 0.06094 seconds
Time After: 0.06134 seconds
Memory Before: 2,758.023 KB
Memory After: 2,758.641 KB
Time Before: 0.06379 seconds
Time After: 0.06503 seconds
Memory Before: 2,770.195 KB
Memory After: 2,770.055 KB
Time Before: 0.06024 seconds
Time After: 0.06531 seconds
Time Taken: 0.00507 seconds
Memory Before: 2,750.172 KB
Memory After: 2,883.414 KB
Memory Used: 133.242 KB
Time Before: 0.11172 seconds
Time After: 0.11192 seconds
Memory Before: 3,436.539 KB
Memory After: 3,437.055 KB
Time Before: 0.14742 seconds
Time After: 0.14867 seconds
Memory Before: 3,524.336 KB
Memory After: 3,524.930 KB
End call of global.php: 0.15065693855286
Time Before: 0.16302 seconds
Time After: 0.16318 seconds
Memory Before: 4,162.242 KB
Memory After: 4,162.672 KB
Time Before: 0.16571 seconds
Time After: 0.16715 seconds
Memory Before: 4,443.805 KB
Memory After: 4,445.492 KB
SET lastactivity = 1782925357, location = '/forums/private.php?do=newpm&explain=1&u=15219'
Time Before: 0.18675 seconds
Time After: 0.18701 seconds
Memory Before: 4,922.117 KB
Memory After: 4,922.320 KB
Memory Used: 0.203 KB
Page generated in 0.18578410148621 seconds with 9 queries, spending 0.0082812309265137 doing MySQL queries and 0.17750287055969 doing PHP things.
