Time Before: 0.00141 seconds
Time After: 0.00184 seconds
Time Before: 0.00191 seconds
Time After: 0.00241 seconds
Time Before: 0.00264 seconds
Time After: 0.00276 seconds
Time Before: 0.00339 seconds
Time After: 0.00633 seconds
Time Taken: 0.00294 seconds
Time Before: 0.00281 seconds
Time After: 0.00969 seconds
Time Taken: 0.00688 seconds
Time Before: 0.01177 seconds
Time After: 0.01218 seconds
Time Before: 0.01449 seconds
Time After: 0.01575 seconds
Time Before: 0.01122 seconds
Time After: 0.01592 seconds
Time Taken: 0.00470 seconds
Time Before: 0.02088 seconds
Time After: 0.02108 seconds
Time Before: 0.02285 seconds
Time After: 0.02411 seconds
Time Before: 0.02705 seconds
Time After: 0.02728 seconds
Time Before: 0.02936 seconds
Time After: 0.03081 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=15343' WHERE sessionhash = '3d710f9993f3eccc4700b01c2edbb01a'
Time Before: 0.04469 seconds
Time After: 0.04500 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
