Time Before: 0.01635 seconds
Time After: 0.02134 seconds
Time Taken: 0.00499 seconds
Time Before: 0.02146 seconds
Time After: 0.02187 seconds
Time Before: 0.02205 seconds
Time After: 0.02219 seconds
Time Before: 0.02289 seconds
Time After: 0.02496 seconds
Time Taken: 0.00207 seconds
Time Before: 0.02224 seconds
Time After: 0.02874 seconds
Time Taken: 0.00651 seconds
Time Before: 0.03813 seconds
Time After: 0.03854 seconds
Time Before: 0.04121 seconds
Time After: 0.04243 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.03752 seconds
Time After: 0.04266 seconds
Time Taken: 0.00514 seconds
Memory After: 2,261.836 KB
Time Before: 0.06589 seconds
Time After: 0.06603 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.24419 seconds
Time After: 0.24579 seconds
Time Taken: 0.00160 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
Time Before: 0.25314 seconds
Time After: 0.25328 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.25569 seconds
Time After: 0.25712 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
UPDATE session SET lastactivity = 1789080781, location = '/forums/private.php?do=newpm&explain=1&u=15382', badlocation = 1 WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.27602 seconds
Time After: 0.27631 seconds
Memory Before: 4,287.859 KB
Memory After: 4,288.070 KB
