Time Before: 0.00140 seconds
Time After: 0.00197 seconds
Time Taken: 0.00057 seconds
Time Before: 0.00203 seconds
Time After: 0.00261 seconds
Time Before: 0.00285 seconds
Time After: 0.00301 seconds
Time Before: 0.00371 seconds
Time After: 0.00604 seconds
Time Taken: 0.00234 seconds
Time Before: 0.00305 seconds
Time After: 0.00947 seconds
Time Taken: 0.00642 seconds
Time Before: 0.01139 seconds
Time After: 0.01176 seconds
Time Before: 0.01414 seconds
Time After: 0.01533 seconds
Time Before: 0.01075 seconds
Time After: 0.01551 seconds
Time Taken: 0.00476 seconds
Time Before: 0.02141 seconds
Time After: 0.02193 seconds
Time Before: 0.02413 seconds
Time After: 0.02538 seconds
Time Before: 0.02931 seconds
Time After: 0.02956 seconds
Time Before: 0.03220 seconds
Time After: 0.03385 seconds
Time Taken: 0.00165 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=15393' WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.04644 seconds
Time After: 0.04702 seconds
Time Taken: 0.00058 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
