Time Before: 0.00143 seconds
Time After: 0.00193 seconds
Time Before: 0.00200 seconds
Time After: 0.00248 seconds
Time Before: 0.00277 seconds
Time After: 0.00290 seconds
Time Before: 0.00368 seconds
Time After: 0.00586 seconds
Time Taken: 0.00218 seconds
Time Before: 0.00297 seconds
Time After: 0.00934 seconds
Time Taken: 0.00637 seconds
Time Before: 0.01128 seconds
Time After: 0.01177 seconds
Time Before: 0.01330 seconds
Time After: 0.01457 seconds
Time Before: 0.01068 seconds
Time After: 0.01475 seconds
Time Taken: 0.00408 seconds
Time Before: 0.02005 seconds
Time After: 0.02020 seconds
Time Before: 0.02203 seconds
Time After: 0.02332 seconds
End call of global.php: 0.025876045227051
Time Before: 0.02751 seconds
Time After: 0.02766 seconds
Time Before: 0.03023 seconds
Time After: 0.03171 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=15425'
Time Before: 0.04402 seconds
Time After: 0.04435 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
Page generated in 0.043117046356201 seconds with 9 queries, spending 0.0079662799835205 doing MySQL queries and 0.035150766372681 doing PHP things.
