Time Before: 0.00234 seconds
Time After: 0.00327 seconds
Time Taken: 0.00093 seconds
Time Before: 0.00334 seconds
Time After: 0.00376 seconds
Time Before: 0.00406 seconds
Time After: 0.00422 seconds
Time Before: 0.00512 seconds
Time After: 0.00885 seconds
Time Taken: 0.00372 seconds
Time Before: 0.00430 seconds
Time After: 0.01225 seconds
Time Taken: 0.00795 seconds
Time Before: 0.01416 seconds
Time After: 0.01455 seconds
Time Before: 0.01620 seconds
Time After: 0.01742 seconds
Time Before: 0.01362 seconds
Time After: 0.01758 seconds
Time Taken: 0.00396 seconds
Time Before: 0.02252 seconds
Time After: 0.02269 seconds
Time Before: 0.02465 seconds
Time After: 0.02589 seconds
End call of global.php: 0.027487993240356
Time Before: 0.02857 seconds
Time After: 0.02874 seconds
Time Before: 0.03068 seconds
Time After: 0.03210 seconds
SET lastactivity = 1788984678, location = '/forums/private.php?do=newpm&explain=1&u=15431'
Time Before: 0.04449 seconds
Time After: 0.04476 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.043543100357056 seconds with 9 queries, spending 0.0091955661773682 doing MySQL queries and 0.034347534179688 doing PHP things.
