Time Before: 0.02645 seconds
Time After: 0.03449 seconds
Time Taken: 0.00804 seconds
Time Before: 0.03460 seconds
Time After: 0.03509 seconds
Time Before: 0.03531 seconds
Time After: 0.03545 seconds
Time Before: 0.03628 seconds
Time After: 0.03920 seconds
Time Taken: 0.00292 seconds
Time Before: 0.03551 seconds
Time After: 0.04352 seconds
Time Taken: 0.00801 seconds
Time Before: 0.05458 seconds
Time After: 0.05498 seconds
Time Before: 0.05769 seconds
Time After: 0.05893 seconds
Time Before: 0.05394 seconds
Time After: 0.05918 seconds
Time Taken: 0.00523 seconds
Time Before: 0.08990 seconds
Time After: 0.09004 seconds
Time Before: 0.10885 seconds
Time After: 0.11011 seconds
Time Before: 0.12522 seconds
Time After: 0.12539 seconds
Time Before: 0.12826 seconds
Time After: 0.12986 seconds
Time Taken: 0.00160 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=15447' WHERE sessionhash = '3d710f9993f3eccc4700b01c2edbb01a'
Time Before: 0.15062 seconds
Time After: 0.15089 seconds
Memory Before: 4,287.734 KB
Memory After: 4,287.977 KB
