Time Before: 0.02219 seconds
Time After: 0.02705 seconds
Time Taken: 0.00486 seconds
Time Before: 0.02716 seconds
Time After: 0.02759 seconds
Time Before: 0.02785 seconds
Time After: 0.02797 seconds
Time Before: 0.02886 seconds
Time After: 0.03105 seconds
Time Taken: 0.00219 seconds
Time Before: 0.02806 seconds
Time After: 0.03500 seconds
Time Taken: 0.00694 seconds
Time Before: 0.04181 seconds
Time After: 0.04221 seconds
Time Before: 0.04498 seconds
Time After: 0.04614 seconds
Time Taken: 0.00116 seconds
Time Before: 0.04110 seconds
Time After: 0.04636 seconds
Time Taken: 0.00526 seconds
Time Before: 0.08775 seconds
Time After: 0.08787 seconds
Time Before: 0.26330 seconds
Time After: 0.26455 seconds
Time Before: 0.27576 seconds
Time After: 0.27593 seconds
Time Before: 0.27862 seconds
Time After: 0.28007 seconds
UPDATE session SET lastactivity = 1785408376, location = '/forums/private.php?do=newpm&explain=1&u=15479', badlocation = 1 WHERE sessionhash = 'dd14cf6af34df6bab38ac9fb3783395f'
Time Before: 0.30263 seconds
Time After: 0.30314 seconds
Memory Before: 4,288.594 KB
Memory After: 4,288.805 KB
