Time Before: 0.00135 seconds
Time After: 0.00199 seconds
Time Taken: 0.00064 seconds
Time Before: 0.00206 seconds
Time After: 0.00270 seconds
Time Before: 0.00294 seconds
Time After: 0.00306 seconds
Time Before: 0.00370 seconds
Time After: 0.00633 seconds
Time Taken: 0.00264 seconds
Time Before: 0.00310 seconds
Time After: 0.00974 seconds
Time Taken: 0.00663 seconds
Time Before: 0.01150 seconds
Time After: 0.01194 seconds
Time Before: 0.01470 seconds
Time After: 0.01611 seconds
Time Before: 0.01095 seconds
Time After: 0.01629 seconds
Time Taken: 0.00534 seconds
Time Before: 0.02116 seconds
Time After: 0.02131 seconds
Time Before: 0.02297 seconds
Time After: 0.02422 seconds
End call of global.php: 0.025833129882812
Time Before: 0.02727 seconds
Time After: 0.02748 seconds
Time Before: 0.02952 seconds
Time After: 0.03094 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=15506', badlocation = 1
Time Before: 0.04340 seconds
Time After: 0.04376 seconds
Memory Before: 4,911.938 KB
Memory After: 4,912.164 KB
Page generated in 0.042505979537964 seconds with 9 queries, spending 0.0086302757263184 doing MySQL queries and 0.033875703811646 doing PHP things.
