Time Before: 0.01417 seconds
Time After: 0.01976 seconds
Time Taken: 0.00559 seconds
Time Before: 0.01984 seconds
Time After: 0.02018 seconds
Time Before: 0.02036 seconds
Time After: 0.02050 seconds
Time Before: 0.02127 seconds
Time After: 0.02385 seconds
Time Taken: 0.00258 seconds
Time Before: 0.02055 seconds
Time After: 0.02798 seconds
Time Taken: 0.00743 seconds
Time Before: 0.03343 seconds
Time After: 0.03381 seconds
Time Before: 0.03526 seconds
Time After: 0.03646 seconds
Time Before: 0.03280 seconds
Time After: 0.03666 seconds
Time Taken: 0.00386 seconds
Time Before: 0.07255 seconds
Time After: 0.07279 seconds
Time Before: 0.08683 seconds
Time After: 0.08810 seconds
End call of global.php: 0.090358018875122
Time Before: 0.09799 seconds
Time After: 0.09816 seconds
Time Before: 0.10090 seconds
Time After: 0.10238 seconds
SET lastactivity = 1782987171, location = '/forums/private.php?do=newpm&explain=1&u=15527'
Time Before: 0.11998 seconds
Time After: 0.12037 seconds
Memory Before: 4,289.125 KB
Memory After: 4,289.352 KB
Page generated in 0.11893105506897 seconds with 9 queries, spending 0.0081913471221924 doing MySQL queries and 0.11073970794678 doing PHP things.
