Time Before: 0.00143 seconds
Time After: 0.00193 seconds
Time Before: 0.00202 seconds
Time After: 0.00246 seconds
Time Before: 0.00267 seconds
Time After: 0.00279 seconds
Time Before: 0.00349 seconds
Time After: 0.00679 seconds
Time Taken: 0.00331 seconds
Time Before: 0.00284 seconds
Time After: 0.01079 seconds
Time Taken: 0.00795 seconds
Time Before: 0.01315 seconds
Time After: 0.01352 seconds
Time Before: 0.01648 seconds
Time After: 0.01767 seconds
Time Before: 0.01243 seconds
Time After: 0.01792 seconds
Time Taken: 0.00549 seconds
Time Before: 0.02325 seconds
Time After: 0.02341 seconds
Time Before: 0.02538 seconds
Time After: 0.02658 seconds
End call of global.php: 0.028237104415894
Time Before: 0.02950 seconds
Time After: 0.02966 seconds
Time Before: 0.03200 seconds
Time After: 0.03345 seconds
SET lastactivity = 1789108889, location = '/forums/private.php?do=newpm&explain=1&u=15539'
Time Before: 0.04700 seconds
Time After: 0.04729 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.046083927154541 seconds with 9 queries, spending 0.0086956024169922 doing MySQL queries and 0.037388324737549 doing PHP things.
