Time Before: 0.02419 seconds
Time After: 0.02767 seconds
Time Taken: 0.00348 seconds
Time Before: 0.02779 seconds
Time After: 0.02823 seconds
Time Before: 0.02847 seconds
Time After: 0.02862 seconds
Time Before: 0.02943 seconds
Time After: 0.03177 seconds
Time Taken: 0.00234 seconds
Time Before: 0.02869 seconds
Time After: 0.03654 seconds
Time Taken: 0.00786 seconds
Time Before: 0.04730 seconds
Time After: 0.04774 seconds
Time Before: 0.05063 seconds
Time After: 0.05189 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.04251 seconds
Time After: 0.05216 seconds
Time Taken: 0.00964 seconds
Memory After: 2,261.836 KB
Time Before: 0.07939 seconds
Time After: 0.07951 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.09177 seconds
Time After: 0.09311 seconds
Time Taken: 0.00134 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
Time Before: 0.09968 seconds
Time After: 0.09981 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.10225 seconds
Time After: 0.10377 seconds
Time Taken: 0.00152 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
UPDATE session SET lastactivity = 1789125327, location = '/forums/private.php?do=newpm&explain=1&u=15781', badlocation = 1 WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.12380 seconds
Time After: 0.12407 seconds
Memory Before: 4,287.859 KB
Memory After: 4,288.070 KB
