Time Before: 0.00163 seconds
Time After: 0.00218 seconds
Time Taken: 0.00054 seconds
Time Before: 0.00228 seconds
Time After: 0.00287 seconds
Time Taken: 0.00059 seconds
Time Before: 0.00312 seconds
Time After: 0.00322 seconds
Time Taken: 0.00010 seconds
Time Before: 0.00389 seconds
Time After: 0.00647 seconds
Time Taken: 0.00259 seconds
Time Before: 0.00328 seconds
Time After: 0.00984 seconds
Time Taken: 0.00656 seconds
Time Before: 0.01154 seconds
Time After: 0.01197 seconds
Time Before: 0.01430 seconds
Time After: 0.01545 seconds
Time Taken: 0.00115 seconds
Time Before: 0.01094 seconds
Time After: 0.01562 seconds
Time Taken: 0.00468 seconds
Time Before: 0.02048 seconds
Time After: 0.02070 seconds
Time Before: 0.02277 seconds
Time After: 0.02469 seconds
Time Taken: 0.00192 seconds
Time Before: 0.02766 seconds
Time After: 0.02786 seconds
Time Before: 0.02999 seconds
Time After: 0.03158 seconds
Time Taken: 0.00160 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=15865' WHERE sessionhash = '295cc732df117534f65c11ae631a16f6'
Time Before: 0.04395 seconds
Time After: 0.04421 seconds
Memory Before: 4,911.656 KB
Memory After: 4,911.898 KB
