Time Before: 0.00207 seconds
Time After: 0.00268 seconds
Time Taken: 0.00061 seconds
Time Before: 0.00278 seconds
Time After: 0.00314 seconds
Time Before: 0.00341 seconds
Time After: 0.00357 seconds
Time Before: 0.00438 seconds
Time After: 0.00771 seconds
Time Taken: 0.00332 seconds
Time Before: 0.00364 seconds
Time After: 0.01208 seconds
Time Taken: 0.00844 seconds
Time Before: 0.01445 seconds
Time After: 0.01485 seconds
Time Before: 0.01754 seconds
Time After: 0.01886 seconds
Time Taken: 0.00132 seconds
Time Before: 0.01371 seconds
Time After: 0.01913 seconds
Time Taken: 0.00542 seconds
Time Before: 0.02643 seconds
Time After: 0.02660 seconds
Time Before: 0.02955 seconds
Time After: 0.03079 seconds
End call of global.php: 0.033151149749756
Time Before: 0.03451 seconds
Time After: 0.03470 seconds
Time Before: 0.03784 seconds
Time After: 0.03930 seconds
SET lastactivity = 1784718046, location = '/forums/private.php?do=newpm&explain=1&u=15868'
Time Before: 0.05880 seconds
Time After: 0.05912 seconds
Memory Before: 4,288.313 KB
Memory After: 4,288.539 KB
Page generated in 0.057460069656372 seconds with 9 queries, spending 0.0089313983917236 doing MySQL queries and 0.048528671264648 doing PHP things.
