Time Before: 0.03234 seconds
Time After: 0.04059 seconds
Time Taken: 0.00826 seconds
Memory Before: 533.906 KB
Memory After: 559.023 KB
Time Before: 0.04070 seconds
Time After: 0.04128 seconds
Time Taken: 0.00058 seconds
Memory Before: 558.961 KB
Memory After: 559.969 KB
Time Before: 0.04152 seconds
Time After: 0.04167 seconds
Memory Before: 560.523 KB
Memory After: 561.047 KB
Time Before: 0.04254 seconds
Time After: 0.04470 seconds
Time Taken: 0.00216 seconds
Memory Before: 563.648 KB
Memory After: 564.570 KB
Time Before: 0.04174 seconds
Time After: 0.04879 seconds
Time Taken: 0.00706 seconds
Memory Before: 560.297 KB
Memory After: 1,641.297 KB
Memory Used: 1,081.000 KB
Time Before: 0.05941 seconds
Time After: 0.05977 seconds
Memory Before: 2,136.141 KB
Memory After: 2,136.758 KB
Time Before: 0.06255 seconds
Time After: 0.06376 seconds
Memory Before: 2,148.203 KB
Memory After: 2,148.063 KB
Time Before: 0.05875 seconds
Time After: 0.06401 seconds
Time Taken: 0.00526 seconds
Memory Before: 2,128.320 KB
Memory After: 2,261.086 KB
Time Before: 0.12264 seconds
Time After: 0.12280 seconds
Memory Before: 2,814.633 KB
Memory After: 2,815.148 KB
Time Before: 0.14762 seconds
Time After: 0.14887 seconds
Memory Before: 2,902.938 KB
Memory After: 2,903.531 KB
End call of global.php: 0.151123046875
Time Before: 0.15949 seconds
Time After: 0.15965 seconds
Memory Before: 3,539.703 KB
Memory After: 3,540.133 KB
Time Before: 0.16280 seconds
Time After: 0.16427 seconds
Memory Before: 3,821.234 KB
Memory After: 3,822.922 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=15883'
Time Before: 0.18393 seconds
Time After: 0.18418 seconds
Memory Before: 4,294.844 KB
Memory After: 4,295.086 KB
Page generated in 0.18286514282227 seconds with 9 queries, spending 0.0077519416809082 doing MySQL queries and 0.17511320114136 doing PHP things.
