Time Before: 0.00155 seconds
Time After: 0.00217 seconds
Time Taken: 0.00062 seconds
Time Before: 0.00228 seconds
Time After: 0.00270 seconds
Time Before: 0.00301 seconds
Time After: 0.00312 seconds
Time Before: 0.00391 seconds
Time After: 0.00673 seconds
Time Taken: 0.00282 seconds
Time Before: 0.00317 seconds
Time After: 0.01179 seconds
Time Taken: 0.00862 seconds
Time Before: 0.01412 seconds
Time After: 0.01453 seconds
Time Before: 0.01731 seconds
Time After: 0.01949 seconds
Time Taken: 0.00218 seconds
Time Before: 0.01334 seconds
Time After: 0.01966 seconds
Time Taken: 0.00632 seconds
Time Before: 0.02483 seconds
Time After: 0.02497 seconds
Time Before: 0.02760 seconds
Time After: 0.02891 seconds
Time Taken: 0.00131 seconds
End call of global.php: 0.030614852905273
Time Before: 0.03241 seconds
Time After: 0.03254 seconds
Time Before: 0.03458 seconds
Time After: 0.03601 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=15908'
Time Before: 0.04918 seconds
Time After: 0.04956 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
Page generated in 0.048204898834229 seconds with 9 queries, spending 0.0093410015106201 doing MySQL queries and 0.038863897323608 doing PHP things.
