Time Before: 0.01909 seconds
Time After: 0.02550 seconds
Time Taken: 0.00642 seconds
Time Before: 0.02559 seconds
Time After: 0.02605 seconds
Time Before: 0.02639 seconds
Time After: 0.02653 seconds
Time Before: 0.02746 seconds
Time After: 0.02967 seconds
Time Taken: 0.00220 seconds
Time Before: 0.02662 seconds
Time After: 0.03540 seconds
Time Taken: 0.00879 seconds
Time Before: 0.04206 seconds
Time After: 0.04241 seconds
Time Before: 0.04499 seconds
Time After: 0.04620 seconds
Time Before: 0.04138 seconds
Time After: 0.04643 seconds
Time Taken: 0.00505 seconds
Time Before: 0.08622 seconds
Time After: 0.08649 seconds
Time Before: 0.10646 seconds
Time After: 0.10816 seconds
Time Taken: 0.00169 seconds
End call of global.php: 0.11014008522034
Time Before: 0.12021 seconds
Time After: 0.12041 seconds
Time Before: 0.12326 seconds
Time After: 0.12475 seconds
SET lastactivity = 1783365283, location = '/forums/private.php?do=newpm&explain=1&u=15919', badlocation = 1
WHERE sessionhash = '32502f71822f8bf82bf8c86767d671b1'
Time Before: 0.14414 seconds
Time After: 0.14441 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
Page generated in 0.14273905754089 seconds with 9 queries, spending 0.0083136558532715 doing MySQL queries and 0.13442540168762 doing PHP things.
