Time Before: 0.00365 seconds
Time After: 0.00446 seconds
Time Taken: 0.00081 seconds
Time Before: 0.00453 seconds
Time After: 0.00494 seconds
Time Before: 0.00512 seconds
Time After: 0.00526 seconds
Time Before: 0.00596 seconds
Time After: 0.00833 seconds
Time Taken: 0.00238 seconds
Time Before: 0.00531 seconds
Time After: 0.01411 seconds
Time Taken: 0.00880 seconds
Time Before: 0.01692 seconds
Time After: 0.01714 seconds
Time Before: 0.01981 seconds
Time After: 0.02102 seconds
Time Before: 0.01606 seconds
Time After: 0.02132 seconds
Time Taken: 0.00526 seconds
Time Before: 0.02887 seconds
Time After: 0.02905 seconds
Time Before: 0.03205 seconds
Time After: 0.03353 seconds
Time Before: 0.03910 seconds
Time After: 0.03928 seconds
Time Before: 0.04173 seconds
Time After: 0.04320 seconds
UPDATE session SET lastactivity = 1785315922, location = '/forums/private.php?do=newpm&explain=1&u=1592', badlocation = 1 WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.05642 seconds
Time After: 0.05670 seconds
Memory Before: 4,911.445 KB
Memory After: 4,911.656 KB
