Time Before: 0.00145 seconds
Time After: 0.00192 seconds
Time Before: 0.00198 seconds
Time After: 0.00246 seconds
Time Before: 0.00268 seconds
Time After: 0.00290 seconds
Time Before: 0.00370 seconds
Time After: 0.00632 seconds
Time Taken: 0.00262 seconds
Time Before: 0.00298 seconds
Time After: 0.01109 seconds
Time Taken: 0.00811 seconds
Time Before: 0.01357 seconds
Time After: 0.01404 seconds
Time Before: 0.01658 seconds
Time After: 0.01784 seconds
Time Before: 0.01275 seconds
Time After: 0.01809 seconds
Time Taken: 0.00534 seconds
Time Before: 0.02461 seconds
Time After: 0.02479 seconds
Time Before: 0.02680 seconds
Time After: 0.02806 seconds
Time Before: 0.03186 seconds
Time After: 0.03205 seconds
Time Before: 0.03434 seconds
Time After: 0.03578 seconds
UPDATE session SET lastactivity = 1780641233, location = '/forums/private.php?do=newpm&explain=1&u=15958' WHERE sessionhash = 'f0a2de90bc45baf36aaf71071f1bfe42'
Time Before: 0.04931 seconds
Time After: 0.04959 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
