Time Before: 0.01966 seconds
Time After: 0.02329 seconds
Time Taken: 0.00363 seconds
Time Before: 0.02339 seconds
Time After: 0.02385 seconds
Time Before: 0.02413 seconds
Time After: 0.02426 seconds
Time Before: 0.02501 seconds
Time After: 0.02722 seconds
Time Taken: 0.00221 seconds
Time Before: 0.02434 seconds
Time After: 0.03136 seconds
Time Taken: 0.00702 seconds
Time Before: 0.03786 seconds
Time After: 0.03835 seconds
Time Before: 0.04080 seconds
Time After: 0.04206 seconds
Time Before: 0.03721 seconds
Time After: 0.04228 seconds
Time Taken: 0.00507 seconds
Time Before: 0.08053 seconds
Time After: 0.08067 seconds
Time Before: 0.09492 seconds
Time After: 0.09624 seconds
Time Taken: 0.00131 seconds
Time Before: 0.10876 seconds
Time After: 0.10894 seconds
Time Before: 0.11174 seconds
Time After: 0.11325 seconds
Time Taken: 0.00151 seconds
UPDATE session SET lastactivity = 1776567493, location = '/forums/private.php?do=newpm&explain=1&u=15975' WHERE sessionhash = '3d710f9993f3eccc4700b01c2edbb01a'
Time Before: 0.13066 seconds
Time After: 0.13091 seconds
Memory Before: 4,288.313 KB
Memory After: 4,288.539 KB
