Time Before: 0.01992 seconds
Time After: 0.02599 seconds
Time Taken: 0.00608 seconds
Memory Before: 1,246.203 KB
Memory After: 1,273.008 KB
Time Before: 0.02610 seconds
Time After: 0.02755 seconds
Memory Before: 1,272.969 KB
Memory After: 1,273.945 KB
Time Before: 0.02782 seconds
Time After: 0.02797 seconds
Memory Before: 1,274.586 KB
Memory After: 1,275.109 KB
Time Before: 0.02893 seconds
Time After: 0.03193 seconds
Time Taken: 0.00300 seconds
Memory Before: 1,277.977 KB
Memory After: 1,278.898 KB
Time Before: 0.02806 seconds
Time After: 0.03629 seconds
Time Taken: 0.00823 seconds
Memory Before: 1,274.391 KB
Memory After: 2,355.609 KB
Memory Used: 1,081.219 KB
Time Before: 0.04370 seconds
Time After: 0.04407 seconds
Memory Before: 2,895.875 KB
Memory After: 2,896.492 KB
Time Before: 0.04666 seconds
Time After: 0.04790 seconds
Memory Before: 2,908.203 KB
Memory After: 2,908.063 KB
Time Before: 0.04298 seconds
Time After: 0.04810 seconds
Time Taken: 0.00512 seconds
Memory Before: 2,888.602 KB
Memory After: 3,021.133 KB
Memory Used: 132.531 KB
Time Before: 0.10027 seconds
Time After: 0.10041 seconds
Memory Before: 3,655.680 KB
Memory After: 3,656.195 KB
Time Before: 0.15013 seconds
Time After: 0.15140 seconds
Memory Before: 4,133.273 KB
Memory After: 4,133.867 KB
Time Before: 0.17573 seconds
Time After: 0.17617 seconds
Memory Before: 5,197.516 KB
Memory After: 5,325.859 KB
Time Before: 0.18212 seconds
Time After: 0.18357 seconds
Memory Before: 5,481.203 KB
Memory After: 5,610.805 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=1615', badlocation = 1 WHERE sessionhash = '8385044bee7d6de684cfeaf823df6777'
Time Before: 0.21176 seconds
Time After: 0.21206 seconds
Memory Before: 5,998.484 KB
Memory After: 5,998.703 KB
