Time Before: 0.01537 seconds
Time After: 0.02026 seconds
Time Taken: 0.00489 seconds
Time Before: 0.02035 seconds
Time After: 0.02084 seconds
Time Before: 0.02150 seconds
Time After: 0.02199 seconds
Time Before: 0.02294 seconds
Time After: 0.02521 seconds
Time Taken: 0.00227 seconds
Time Before: 0.02207 seconds
Time After: 0.02993 seconds
Time Taken: 0.00786 seconds
Time Before: 0.03665 seconds
Time After: 0.03689 seconds
Time Before: 0.04001 seconds
Time After: 0.04124 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.03603 seconds
Time After: 0.04145 seconds
Time Taken: 0.00543 seconds
Memory After: 2,261.719 KB
Time Before: 0.06412 seconds
Time After: 0.06429 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.07433 seconds
Time After: 0.07569 seconds
Time Taken: 0.00136 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
End call of global.php: 0.078094959259033
Time Before: 0.08325 seconds
Time After: 0.08340 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.08573 seconds
Time After: 0.08715 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=16202', badlocation = 1
Time Before: 0.10349 seconds
Time After: 0.10376 seconds
Memory Before: 4,287.500 KB
Memory After: 4,287.727 KB
Page generated in 0.10250902175903 seconds with 9 queries, spending 0.0080976486206055 doing MySQL queries and 0.094411373138428 doing PHP things.
