Time Before: 0.00265 seconds
Time After: 0.00395 seconds
Time Before: 0.00403 seconds
Time After: 0.00467 seconds
Time Taken: 0.00064 seconds
Time Before: 0.00502 seconds
Time After: 0.00515 seconds
Time Before: 0.00599 seconds
Time After: 0.00954 seconds
Time Taken: 0.00355 seconds
Time Before: 0.00521 seconds
Time After: 0.01310 seconds
Time Taken: 0.00789 seconds
Time Before: 0.01549 seconds
Time After: 0.01592 seconds
Time Before: 0.01866 seconds
Time After: 0.01988 seconds
Time Before: 0.01483 seconds
Time After: 0.02006 seconds
Time Taken: 0.00523 seconds
Memory After: 2,885.219 KB
Memory Used: 132.898 KB
Time Before: 0.02623 seconds
Time After: 0.02638 seconds
Memory Before: 3,438.320 KB
Memory After: 3,438.836 KB
Time Before: 0.02874 seconds
Time After: 0.02996 seconds
Memory Before: 3,526.016 KB
Memory After: 3,526.609 KB
Time Before: 0.03304 seconds
Time After: 0.03319 seconds
Memory Before: 4,163.914 KB
Memory After: 4,164.344 KB
Time Before: 0.03557 seconds
Time After: 0.03898 seconds
Time Taken: 0.00340 seconds
Memory Before: 4,445.453 KB
Memory After: 4,447.141 KB
UPDATE session SET lastactivity = 1789122300, location = '/forums/private.php?do=newpm&explain=1&u=16296', badlocation = 1 WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.05168 seconds
Time After: 0.05217 seconds
Memory Before: 4,911.430 KB
Memory After: 4,911.641 KB
