Time Before: 0.00188 seconds
Time After: 0.00240 seconds
Memory Before: 533.906 KB
Memory After: 559.023 KB
Time Before: 0.00247 seconds
Time After: 0.00336 seconds
Time Taken: 0.00088 seconds
Memory Before: 558.961 KB
Memory After: 559.969 KB
Time Before: 0.00354 seconds
Time After: 0.00369 seconds
Memory Before: 560.523 KB
Memory After: 561.047 KB
Time Before: 0.00440 seconds
Time After: 0.00704 seconds
Time Taken: 0.00264 seconds
Memory Before: 563.648 KB
Memory After: 564.570 KB
Time Before: 0.00373 seconds
Time After: 0.01240 seconds
Time Taken: 0.00867 seconds
Memory Before: 560.297 KB
Memory After: 1,641.297 KB
Memory Used: 1,081.000 KB
Time Before: 0.01480 seconds
Time After: 0.01519 seconds
Memory Before: 2,136.141 KB
Memory After: 2,136.758 KB
Time Before: 0.01791 seconds
Time After: 0.01915 seconds
Memory Before: 2,148.320 KB
Memory After: 2,148.180 KB
Time Before: 0.01408 seconds
Time After: 0.01934 seconds
Time Taken: 0.00526 seconds
Memory Before: 2,128.320 KB
Memory After: 2,261.203 KB
Time Before: 0.02483 seconds
Time After: 0.02497 seconds
Memory Before: 2,814.781 KB
Memory After: 2,815.297 KB
Time Before: 0.02746 seconds
Time After: 0.02870 seconds
Memory Before: 2,903.117 KB
Memory After: 2,903.711 KB
End call of global.php: 0.031258821487427
Time Before: 0.03258 seconds
Time After: 0.03278 seconds
Memory Before: 3,539.836 KB
Memory After: 3,540.266 KB
Time Before: 0.03519 seconds
Time After: 0.03660 seconds
Memory Before: 3,821.367 KB
Memory After: 3,823.055 KB
SET lastactivity = 1788849021, location = '/forums/private.php?do=newpm&explain=1&u=16299'
Time Before: 0.04920 seconds
Time After: 0.04966 seconds
Memory Before: 4,295.203 KB
Memory After: 4,295.430 KB
Page generated in 0.048342943191528 seconds with 9 queries, spending 0.0087621212005615 doing MySQL queries and 0.039580821990967 doing PHP things.
